TCustomRVReportGenerator.OnError
Occurs if an error happens while generating a report.
type
  TRVReportGeneratorError = (
    // rules
    rvrgeRuleInvalidRange, rvrgeRuleOverlaps,
    // queries
    rvrgeNoQueryProcessor, rvrgeQueryExecution,
    rvrgeRecordCountIsRequired,
    // variables
    rvrgeVariableUnknown, rvrgeVariableInvalidValue,
    rvrgeVariableInvalidName, rvrgeVariableUnsupportedObject,
    // data fields
    rvrgeFieldUnknown, rvrgeFieldInvalidValue,
    rvrgeFieldUnsupportedType, rvrgeFieldUnknownType,
    rvrgeFieldUnknownRule,
    // fields
    rvrgeInvalidTypeCast, rvrgeInvalidFormatString,
    rvrgeCustomFieldTypeError,
    // commands
    rvrgeCommandUnknown, rvrgeCommandNeedsParam,
    rvrgeCommandDoesNotNeedParam, rvrgeCommandWrongParamValue,
    rvrgeCommandSyntaxError, rvrgeCommandUnmatched,
    rvrgeCommandMustBeInQuery, rvrgeCommandWrongContext,
    // cross-tab
    rvrgeCrossTabInvalid, rvrgeCrossTabInvalidPosition,
    rvrgeCrossTabNoRules,
    rvrgeCrossTabUnknownField,
    rvrgeCrossTabWrongContext, rvrgeCrossTabRecordDoesNotMatch,
    rvrgeCrossTabDuplicateRecords,
    rvrgeCrossTabKeyFieldInCrossTabColumn,
    rvrgeCrossTabNoCrossTabColumns, rvrgeCrossTabTooManyColumns,
    rvrgeCrossTabTooManyTotalColumns,
    // functions
    rvrgeFuncParenthesisExpected, rvrgeFuncUnknown,
    rvrgeFuncBadParam, rvrgeFuncMustBeInCrossTabSummary,
    rvrgeFuncCannotBeCalculated,
    // expressions
    rvrExpressionParserError, rvrExpressionEvaluationError,
    // others
    rvrgeInternalError
  TRVReportGeneratorErrorEvent = procedure (
    Sender: TCustomRVReportGenerator;
    ErrorCode: TRVReportGeneratorError;
    const RelatedText: TRVUnicodeString;
    RelatedObject: TObject; var Proceed: Boolean) of object;
property OnError: TRVReportGeneratorErrorEvent;
This event can be processed:
to display an error message,
to abort a report generation on some (or all) errors.
By default, this event is called in the context of the main process (even if reports are generated in a background thread), to allow interacting with user interface controls. If you want to call it in a thread context, exclude rvrgeOnError from SynchronizedEvents.
Parameters
ErrorCode – a code identifying the error.
RelatedText, RelatedObject provide additional information about this error.
You can assign False to Proceed to abort the report generation. In this case, this error is treated as critical, and Execute will return False.
Errors while checking table row generation rules for correctness
For this kind of errors, RelatedObject is TRVRowGenerationCustomRule.
Error
Meaning
RelatedText
The rule has an incorrect range of rows (too small or too large row indexes, or these rows overlap other rows because their cells are merged vertically).
Empty
rvrgeRuleOverlaps
The rule has a range of rows intersecting with one of the previous rules in the same table
Empty
Errors while executing a data query (such as SQL SELECT statement)
For this kind of errors, RelatedObject is either TRVRowGenerationCustomRule or TRVReportTableCellData.
Error
Meaning
RelatedText
The report generator was not able to create a query processor for this data query.
Data query string
rvrgeQueryExecution
An error occurred while executing a data query
Data query string
This type of report requires a known record count before retrieving data, but the query processor cannot provide it. In the current version, a record count is needed: for column copying in row generation rules, for cross-tab reports
Empty
Errors while processing variables
For this kind of errors, RelatedObject is TRVReportGenerationSession.
Error
Meaning
RelatedText
A field refers to a non-existent variable
Variable name
An improper value of a variable. For example, a variable in "If" command cannot be evaluated as True or False.
Field code
An incorrect (for example, empty) variable name
Variable name
A field needs insertion of an object associated with a variable, and this object has a class unsupported by the report generator
Variable name
Errors while processing data fields
Error
Meaning
RelatedText
rvrgeFieldUnknown
A field refers to a non-existent data field
Data field name
An improper value of a a data field. For example, a data field in "If" command cannot be evaluated as True or False, or a format of content of a Blob field cannot be detected
Field code or data field name
A data field has an unsupported type
Data field name
A field refers to a non-existent row generation rule
Rule name
Common errors while processing data fields, cross-tab header fields, functions
Error
Meaning
RelatedText
Unknown value in <field type>
Field code
The value cannot be converted to <field type>
Field code
Error in <format string>
Field code
An error was reported by a custom field type handler. The reason may be because the field data are inappropriate, or a format string is erroneous.
Field code
Errors while processing commands
Error
Meaning
RelatedText
rvrgeCommandUnknown
Unknown command
Field code
This command requires parameter(s)
Field code
This command requires no parameters
Field code
A parameter value for this command is incorrect
Field code
A syntax error in the command code
Field code
Unmatched commands (for example, "If" without "EndIf")
Field code
This command must be inserted in a text affected by a data query
Field code
This command is not valid in this place of document (for example, "ListReset" command must be in a numbered paragraph)
Field code
Errors while making a cross-tab report
Error
Meaning
RelatedText
RelatedObject
Table.CrossTabulation is incorrect.
Possible reasons:
empty Table.CrossTabulation.Levels[].FieldName;
empty Table.CrossTabulation.Levels[].DataQuery, if they are required for the given ColumnGenerationType;
invalid values (or a combination of values) for MinValue, MaxValue, Step, if ColumnGenerationType = rvcgtRange
Empty
TRVReportTableItemInfo
Position or structure of a cross-tab header is incorrect.
Empty
A cross tabulation is defined for a table, but this table has no row generation rules, or the first rule is invalid
Empty
Table.CrossTabulation.Levels[].FieldName or CaptionFieldName does not exists in the results of the respective data query (if ColumnGenerationType <> rvcgtRange)
Field name
TRVCrossTabLevel
A cross-tab header field refers to a non-existent data field
Field name
A cross-tab header field is found outside a cross-tab header cells
Field code
A record in the result of a row generation rule's DataQuery contains a combination of values of column fields not corresponding to any cross-tab data column
Empty
A record in the result of a row generation rule's DataQuery contains the same combination of values of key fields and column fields as one of previous records.
Empty
One ore more key fields is included in column fields
Field name
TRVRowGenerationRule
A cross tabulation contains 0 data columns
Empty
TRVReportTableItemInfo or TRVCrossTabLevel, depending on ColumnGenerationType
A group of columns in a cross-tab level exceeds level.MaxColCount. In this case, only the first MaxColCount columns are used.
Empty
TRVCrossTabLevel
A total number of column repetitions exceeds MaxColCount
Empty
Errors while processing functions
Error
Meaning
RelatedText
An opening or closing bracket around the function parameter is missing
Field code
rvrgeFuncUnknown
Unknown function name
Field code
rvrgeFuncBadParam
A function parameter is not a valid value field name
Field code
A function field is inserted not in a proper place
Field code
Errors while processing expressions
For this kind of errors, RelatedObject is TRVExpressionCalculator.
Error
Meaning
RelatedText
An error occurs when parsing the expression
Expression text
An error occurs when evaluating the expression
Expression text
RelatedObject (TRVExpressionCalculator) allows receiving additional information about the reason of this error and the position in expression where it happened.
Other errors
Error
Meaning
RelatedText
RelatedObject
rvrgeInternalError
An exception occurred while generating a report
Exception message
Exception
Example 1
How to process error messages in OnError event.
Before using RVReportGetErrorString, call RWA_LocalizeErrorMessages.
procedure TForm1.RVReportGenerator1Error(
  RelatedObject: TObject; var Proceed: Boolean);
  Msg1, Msg2: TRVUnicodeString;
const
  MaxErrorCount = 1000;
  if lstMessages.Items.Count = MaxErrorCount then
    lstMessages.Items.Add(RWA_GetS(rwm_log_TooManyErrors));
  if lstMessages.Items.Count > MaxErrorCount then
  RVReportGetErrorString(ErrorCode, Msg1, Msg2, RelatedObject);
  if Msg1 <> '' then
    Msg2 := Msg1 + ': ' + Msg2;
  Msg2 := Format(String(Msg2), [RelatedText]);
  lstMessages.Items.Add(String(Msg2));
Example 2
This example shows how to use custom error messages. This example is simplified, it does not provide detailed information about errors in expressions.
const ErrorMsg: array[TRVReportGeneratorError] of String =
   'Rule error: invalid row or column range',
   'Rule error: overlapping rows',
   'Query error: can''t create query processor for %s',
   'Query error: execution error for %s',
   'Query error: this type of report requires a known record count before retrieving records',
   'Variable error: unknown variable %s',
   'Variable error: invalid value for %s',
   'Variable error: invalid name %s',
   'Variable error: unsupported object in %s',
   'Data field error: unknown field %s',
   'Data field error: invalid value for %s',
   'Data field error: unsupported field type for %s',
   'Data field error: invalid type in %s',
   'Data field error: unknown row generation rule in the field %s',
   'Field error: invalid type casting in %s',
   'Field error: invalid format string %s',
   'Field error: invalid data or format string for a custom field type',
   'Command error: unknown command %s',
   'Command error: parameters are required in %s',
   'Command error: this command must not have parameters: %s',
   'Command error: wrong parameter value: %s',
   'Command error: syntax error %s',
   'Command error: unmatched command %s',
   'Command error: a command must be in content affected by a query: %s',
   'Command error: the command is not valid in its context: %s',
   'Cross-tab error: invalid cross-tab definition',
   'Cross-tab error: invalid cross-tab header location',
   'Cross-tab error: at least one row generation rule is required',
   'Cross-tab error: unknown field %s',
   'Cross-tab error: cross-tab field must be in a cross-tab header',
   'Cross-tab error: a record does not match the cross-tab columns (will be skipped)',
   'Cross-tab error: two or more records match the same cross-tab cell (all but the first one will be skipped)',
   'Cross-tab error: the same field is used both as a key field as a cross-tab header field: %s',
   'Cross-tab error: no columns',
   'Cross-tab error: too many columns in a group',
   'Cross-tab error: too many total columns',
   'Function error: parenthesis is expected in %s',
   'Function error: unknown function %s',
   'Function error: bad parameters in %s',
   'Function error: function must be in a cross-tab summary rows or columns',
   'Function error: function cannot be calculated',
   'Expression parsing error in %s',
   'Expression evaluation error: %s',
   'Internal error'
var S: TRVUnicodeString;
  S := Format(ErrorMsg[ErrorCode], [RelatedText]);
  Memo1.Lines.Add(S);
