Template syntax | Data Field Types
A type may be specified explicitly in:
data fields
cross-tab header fields
functions
expressions
Syntax
<field type> ::= text | int | float | bool | datetime | date | time | minutes | seconds | mseconds | blob | ansimemo | unicodememo | document | rtf | rvf | docx | html | markdown | image | bitmap | gif | png | jpeg | tiff | icon | metafile | <alternative rvf name> | <custom field type>
<alternative rvf name> is a text of RVReportGenerator.Texts.RVF.
Description
If specified, it is one of: text, int, float, bool, datetime, date, time, minutes, seconds, mseconds, blob, ansimemo, unicodememo, document, rtf, docx, html, markdown, rvf, image, bitmap, gif, png, jpeg, tiff, icon, metafile. As you can see, these types correspond to TRVReportFieldType.
Additionally, the value RVReportGenerator.Texts.RVF is treated as 'rvf'.
Additionally, programmers can register their own field types.
Field type
Meaning
text
text string, may be multiline
int
integer value (Int64)
float
floating point value (Extended for Delphi 2009 or newer, Double otherwise)
bool
boolean value
datetime
date and time (TDateTime)
date
date (TDateTime)
time
time (TDateTime)
minutes
converts integer value (number of minutes) to time (TDateTime)*
seconds
converts integer value (number of seconds) to time (TDateTime)*
mseconds
converts integer value (number of milliseconds) to time (TDateTime)*
blob
BLOB field containing either a document or a graphic; the actual content type is detected by format**,***,****
ansimemo
BLOB field containing ANSI text**, HTML, or RTF
unicodememo
BLOB field containing either Unicode (UTF-16) text or RTF (converted to UTF-16), or HTML (in UTF-16 encoding)
document
BLOB field containing text**,***, RTF****, DocX, HTML, or RVF
rtf
RTF****
docx
Microsoft Word Document (DocX)
html
HTML
markdown
Markdown (in UTF-8 encoding)
rvf, RVReportGenerator.Texts.RVF
RVF
graphic; format is detected by content
graphic of the specific format
* the result must be less than 24 hours
** if the field contains text, the report generator tries to detect if it contains Unicode (UTF-16) or ANSI
*** ANSI text encoding is defined in DefCodePage property of TRVStyle component linked to the editor containing the report template; by default, this is a default Windows code page
**** if the field contains RTF, the report generator tries to detect if RTF codes are stored as Unicode (UTF-16) or ANSI
There are several reasons to specify a type:
converting value to another format (for example, float to int, datetime to date)
more efficient processing (for example, blob to rvf allows skipping a format detection step)
allowing to use format string from another field type (for example, int to float allows formatting integer values as floating point values)
ignoring a field type returned by a query processor, and using the specified type;
specifying a format that cannot be auto-detected (markdown)
visualizing values in special ways (especially when using custom field types).
Field types in extension
Barcodes with Zint for Delphi adds two new field types: barcode and qrcode.
Possible data field conversions
Not all combination of the original type and the specified type are allowed. If a combination of types is incorrect, the specified type is ignored.
All types can be converted to 'text' (pictures are converted to empty text).
Additionally, the following conversions are possible.
Original field type
Can be converted to...
text
int, bool, float, datetime, date, time, datetime
int, float, bool
int, float, bool, minutes, seconds, mseconds
time, date, datetime
blob, ansimemo, unicodememo, document, rtf, docx, rvf, html, markdown, image, bitmap, gif, png, jpeg, tiff, icon, metafile
Notes:
when converting non-blob types, the value is received from a query processor basing on its original type; then this value is converted to the specified type
when converting any blob type to each other or to "text", no value conversion occurs; instead, a report generator tries to load content in the specified format.
when converting to bool, the same rules are used as for the conversions in expressions.
when converting bool to int or float, False is converted to 0, True to 1.
Custom field types
Programmers can implement additional data types. Objects that process custom data types can get initial value and return its different representation; additionally, they can [pre]process format strings.
For example, RVReportSampleFieldObjects unit implements the following additional field types:
num2words – spells a number in English (int to text); for example, '{value num2words}' for value 21 returns 'twenty one';
uppercase – returns text in upper case (text to text); for example '{name uppercase}' for 'John' returns 'JOHN';
star – returns an image of a star having as many points as defined in the input value (int to bitmap); this field type processes format strings itself; example: '{value start "size=100 color=red linecolor=blue gradient=1 middlepercent=60"}'
imageinfo – returns text describing the input image (image to text); it returns text like '[Image 250×150]'
See also: extending Report Workshop
