Template syntax | Cross-Tab Header Fields
See the topic about fields in templates for a general description of the syntax.
See the topic about cross-tab reports.
Syntax
<cross-tab header> ::= [']#<cross-tab field>['][ <field type>][ "<format>"]
A cross-tab field name (including the starting '#' character) may be enclosed in single quotes. These single quotes are necessary, if it contains space characters.
<cross-tab field> is a value of one of fields specified in Table.CrossTabulation.Levels[].FieldName or Table.CrossTabulation.Levels[].CaptionFieldName.
Field names are case insensitive.
About cross-tab header fields
References to cross-tab fields may occur:
in cells of the cross-tab header;
in Table.CrossTabulation.Levels[].DataQuery, if Table.CrossTabulation.ColumnGenerationType=rvcgtDataQueryCascade
In the first case, you can refer to fields corresponding to the cross-tabulation level of this cell, and to fields corresponding to higher levels of the cross-tabulation.
In the second case, you can refer to fields corresponding to higher levels of the cross-tabulation.
<cross-tab field> can be empty. Such field is an equivalent to the lowest available cross-tab level.
Cross-tab header field types
Report Workshop supports the following types of cross-tab header fields (when referring to a value of FieldName field):
text
integer value
floating point value
boolean
date, time, date and time.
When referring to a value of CaptionFieldName, the field type is always text.
You can override the field type by specifying <field type>, read the topic about specifying data field types.
Cross-tab header field's format strings
Read the topic about format strings.
Example
Let we have:
Table.CrossTabulation.Levels[0].CaptionFieldName = 'Category'
Table.CrossTabulation.Levels[1].CaptionFieldName = 'Product'
A cross-tab report table may look like it is shown below (the pink color denotes cross-tab header cells corresponding to data columns, the light blue color denotes a header for a summary column):
{#Category}
{#Product}
Total for {#Category}
{Year}
{Sales}
{sum(Sales)}
The same report table can be written in a shorter way:
{Year}
{Sales}
{sum(Sales)}
Additional examples can be found:
in the topic about a cross-tab header (replacing fields in header cells)
in the topic about cross-tab data queries (replacing fields in cross-tab data queries)
