TCustomRVReportGenerator.OnError
This event is called when report generation is finished.
type
  TRVReportGeneratedEvent = procedure (Sender: TObject;
    Res: Boolean) of object;
property OnGenerated: TRVReportGeneratedEvent;
If Execute is called with the parameter UseThread = False, this event is called by the Execute method itself. In this case, processing this event is not necessary: you can do all processing after calling Execute.
If Execute is called with the parameter UseThread = True, this method only starts report generation in a background thread, and exits immediately. This event is called when the thread finishes generating a report.
In all cases, this event is called in the context of the main process, so you can safely work with user interface in this event.
