TCustomRVReportGenerator.OnGetField
Occurs before reading a data field value.
type
  TRVReportGeneratorGetFieldEvent = procedure (
    Sender: TCustomRVReportGenerator;
    const QueryProcessorName, FieldName: TRVUnicodeString;
    Session: TRVReportGenerationSessionof object;
property OnGetField: TRVReportGeneratorGetFieldEvent;
This event may occur multiple times when a report is being generated. It is called when processing data fields (for every data field in a report template, for every processed record).
If Execute is called with parameter UseThread = True, this event is called in a thread context.
This is an informational event, it cannot be used to modify generated reports.
Parameters
QueryProcessorName – name of query processor, read from a data field;
FieldName – field name, read from a data field;
Session – an object representing a report generation session.
See also
