TCustomRVReportGenerator.SynchronizedEvents
A set of events that are always called in the context of the main process.
type
  TRVReportGeneratorEventId =
    (rvrgeOnDataQueryProgress, rvrgeOnError);
  TRVReportGeneratorEventIds =
     set of TRVReportGeneratorEventId;
property SynchronizedEvents: TRVReportGeneratorEventIds;
Events included in this property are called in the context of the main process, even if reports are generated in a background thread (so you can work with user interface controls safely).
Value
Event
OnDataQueryProgress
rvrgeOnError
OnError
Default value:
[rvrgeOnDataQueryProgress, rvrgeOnError]
See also:
Execute method
