TrvActionInsertNumber is the action for "Insert Number..." command.
Unit RichViewActions;
Syntax
TrvActionInsertNumber = class(TrvActionInsertNumSequence)
Description
This action displays a dialog window allowing to enter properties of an item to insert.
The following properties are supported:
•sequence name (identifier);
•numbering type (decimal, lower Roman, etc.);
•continue numbering / start from the specified value.
If UseDefaults=True, the dialog is initialized with a sequence name 'Numbering' (localized string) and a decimal numbering type.
When the user clicks the "Insert" button, a "numbered sequence" item is inserted in the caret position, UseDefaults is reset to False, and chosen values are stored in SeqName and NumberType properties (they are used to initialize a dialog when it will be displayed for the next time).
