       << Click to display table of contents >> TrvActionInsertNumSequence |
TrvActionInsertNumSequence is a base class for the actions inserting a "numbered sequence" item.
Unit RichViewActions;
Syntax
TrvActionInsertNumSequence = class(TrvAction)
Description
This action is not used directly.
The following actions are inherited from it:
•TrvActionInsertNumber
•TrvActionInsertCaption
