       << Click to display table of contents >> TrvActionInsertHyperlink.OnHyperlinkForm |
Allows displaying your own hypertext dialog.
type
TRVHyperlinkFormEvent = procedure (Sender: TObject; InsertNew: Boolean;
var Text, Target: TRVUnicodeString; var Proceed: Boolean) of object;
property OnHyperlinkForm: TRVHyperlinkFormEvent;
Use this event if you want to replace the default dialog used in this action.
Input parameters:
If InsertNew=True, this event is called for inserting a new hyperlink.
Text – the selected text, valid only if InsertNew=False.
Target – hypertext target of selected text, use only if InsertNew=False. It is not empty only in case when the selection contains only hyperlinks with equal targets.
Proceed = True.
Output parameters:
Text – text for new hyperlink, used only if InsertNew=True.
Target – hyperlink target. You can return empty string only if InsertNew=False (to remove hyperlinks from the selection)
Proceed must be True if the user pressed "OK", and False if the user pressed "Cancel".
