       << Click to display table of contents >> TrvActionInsertHyperlink.OnGetHyperlinkTargetFromItem |
Occurs when the action needs to get a hyperlink target from item of unknown type.
type
TRVGetHyperlinkTargetFromItem = procedure (Sender: TObject;
Editor: TCustomRichViewEdit; RVData: TCustomRVData; ItemNo: Integer;
var Target: TRVUnicodeString) of object;
property OnGetHyperlinkTargetFromItem: TRVGetHyperlinkTargetFromItem;
For text and pictures, the action gets targets automatically. For items of other types, this event occurs.
If you return empty Target, the action will treat this item as non-hypertext.
The item is defined by Editor and ItemNo (it is the ItemNo-th item in Editor, where Editor can be a main editor or cell inplace editor). RVData is Editor.RVData.
