       << Click to display table of contents >> TrvActionInsertNumSequence.SeqName |
A name (identifier) of the numbered sequence. The inserted item will continue numbering started by items having the same sequence name.
property SeqName: TRVUnicodeString;
If UseDefaults=False, this property is used to initialize a sequence name field in a dialog.
This property is updated automatically to the value entered in this field, when this dialog is applied.
The following sequence names are not allowed (the "Insert" button is disabled if they are entered):
•empty strings
•strings started from '@'
