       << Click to display table of contents >> TrvActionInsertNumSequence.UseDefaults |
Specifies whether values of SeqName and NumberType properties are used.
property UseDefaults: Boolean
When this property is True, the following values are used to initialize a dialog:
•sequence name = 'Numbering' (localized) for TrvActionInsertNumber or 'Figure' (localized) for TrvActionInsertCaption;
•numbering type = decimal.
When this property is False, values of SeqName and NumberType properties are used instead.
After an insertion, this property is reset to False automatically.
Initial value:
True
