       << Click to display table of contents >> TSRVScrollBar.Flat |
Makes the scrollbar "flat".
property Flat: Boolean;
If True, the scrollbar looks flat and does not has a frame around it.
This flat appearance is used if:
•Windows themes are not active (see UseXPThemes), and
•a skin is not applied (see SkinManager, SkinSchemeIndex), and
•SRVControlStyle = srvcsClassic
Default value
False
