       << Click to display table of contents >> TSRVScrollBar.DecButtonWidth |
Specifies width of the button for scrolling to the beginning.
property DecButtonWidth: TRVPixel96Length;
If value of this property is 0, a system default value is used. Values less than 5 are treated as 5.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value
0
