       << Click to display table of contents >> TSRVScrollBar.UseXPThemes |
Specifies whether the scrollbar uses VCL and Windows themes (visual styles), if they are available.
property UseXPThemes: Boolean;
VCL/Windows themes are used by the scrollbar if:
•it is not skinned (SkinManager = nil, or SkinManager.CurrentSkin = nil, SkinSchemeIndex is not valid) and
•SRVControlStyle = srvcsClassic
If a VCL theme is active (in Delphi XE2 or newer), it is used for drawing. Otherwise, Windows theme is used.
Note: when this scrollbar is inserted in a TSRichViewEdit document, theme drawing is scaled not completely correctly. We recommend using SRVControlStyle = srvcsSimple instead.
Default value
True
