       << Click to display table of contents >> TSRVScrollBar.SRVControlStyle |
Define appearance of this scrollbar.
property SRVControlStyle: TSRVControlStyle;
This property is used if a skin is not assigned (see SkinManager and SkinSchemeIndex).
srvcsSimple (an example view if RVControlsPainter.Theme = rvctPaleBlue):
srvcsClassic:
If UseXPThemes = True, the scrollbar uses VCL themes (if available) or Windows themes (if available). Otherwise, the scrollbar has 3d look. When the scrollbar is inserted in a TSRichViewEdit document, theme drawing is scaled not completely correctly. We recommend using srvcsSimple instead.
Default value:
srvcsClassic
This is the only control in ScaleRichView/SRVControls that has SRVControlStyle = srvcsClassic by default.
