TRVReportDocObject.Script_OnStart, Script_AfterRecord, Script_AfterRecord, Script_OnEnd
Scripts that are executed when a report is generated.
property Script_OnStart: TStrings;
property Script_BeforeRecord: TStrings;
property Script_AfterRecord: TStrings;
property Script_OnEnd: TStrings;
If DataQuery is not empty:
Script_OnStart is executed at the beginning of report generation, just after the DataQuery is executed.
Script_BeforeRecord is executed before processing each record of DataQuery results.
Script_AfterRecord is executed after processing each record of DataQuery results.
Script_OnEnd is executed at the end of report generation.
If DataQuery is empty:
For empty scripts, these properties may return nil.
Assignment to these properties copies TString object.
Default value:
Nil
See also
RVReportGetScript, RVReportSetScript, RVReportSetScriptAsString functions and procedures
scripts associated with table generation rules
