TRVRowGenerationRule.Script_OnStart, Script_AfterRecord, Script_OnEnd
Scripts that are executed when this row generation rule is applied.
property Script_OnStart: TStrings;
property Script_BeforeRecord: TStrings;
property Script_AfterRecord: TStrings;
property Script_OnEnd: TStrings;
Script_OnStart is executed before the rule is applied, just after the DataQuery is executed.
Script_BeforeRecord is executed before processing each record of DataQuery results.
Script_AfterRecord is executed after processing each record of DataQuery results.
Script_OnEnd is executed at the end of the rule application.
Assignment to these properties copies TString object.
See also
scripts associated with the whole report
