TRVReportDocObject.PageBreaksBetweenCopies
Specifies whether the report generator must add page breaks between copies of data generated when applying DataQuery.
property PageBreaksBetweenCopies: Boolean;
This property is used only if DataQuery is not empty.
Default value:
False
See also
RVReportGetPageBreaksBetweenCopies function
RVReportSetPageBreaksBetweenCopies procedure
