       << Click to display table of contents >> TrvActionFontEx.CharScale |
Specifies the character scale ratio for applying to the selected text.
property CharScale: Integer;
If UserInterface=False and rvfimCharScale in ValidProperties, the action applies this property to the selected text.
If UserInterface=True, the action displays a font dialog (initialized with font properties of the selected text); if the user changed value of this property in the dialog, rvfimCharScale is included in ValidProperties, and the action applies this property to the selected text.
This property is applied to the text style's (RVStyle.TextStyles[]) property of the same name.
