       << Click to display table of contents >> TrvActionFonts.UserInterface |
Allows working with or without the user interaction.
property UserInterface: Boolean;
If UserInterface=False, the action applies its properties to the selected text.
If UserInterface=True, the action displays a font dialog, assigns changes to the action's properties, and then applies these properties to the selected text.
Default value:
True
