       << Click to display table of contents >> TrvActionFontEx.ValidProperties |
Defines a set of properties for applying to the selected text.
type
TRVFontInfoMainProperty = (rvfimFontName, rvfimSize, rvfimCharset,
rvfimBold, rvfimItalic, rvfimUnderline, rvfimStrikeout,
rvfimOverline, rvfimAllCaps, rvfimVShift, rvfimColor, rvfimBackColor,
rvfimCharScale, rvfimCharSpacing, rvfimSubSuperScriptType,
rvfimUnderlineType, rvfimUnderlineColor);
TRVFontInfoMainProperties = set of TRVFontInfoMainProperty;
property ValidProperties: TRVFontInfoMainProperties;
If UserInterface=False, assign a subset of properties (for applying) to ValidProperties.
If UserInterface=True, this property is maintained automatically. After displaying a font dialog, this property contains a set of properties corresponding to non-blank fields in the dialog.
For properties-sets (Font.Style and FontStyleEx) each value in the set is represented by one value in this property. For example:
•if rvfimOverline in ValidProperties, rvfsOverline in FontStyleEx, the selected text will be overlined;
•if rvfimOverline in ValidProperties, rvfsOverline not in FontStyleEx, overlines will be removed from the selected text;
•if rvfimOverline not in ValidProperties, overlines in the selected text will not be affected.
