       << Click to display table of contents >> Interfaces | Spelling Check Interfaces |
Spelling check interfaces allow using third-party components to correct spelling errors in TRichViewEdit.
To use a spelling check interface component, assign it to SpellInterface property of TRVAControlPanel component.
Then you can:
•use TrvActionSpellingCheck action
•use TrvActionThesaurus action (if the chosen interface component supports a thesaurus)
•call its AutoCorrectInKeyDown in the editor's OnKeyDown event and AutoCorrectInKeyPress in the editor's OnKeyPress event to perform auto-correction on typing (if the chosen interface component supports an auto-correction)
•assign the inverted result of its IsWordValid method to the Misspelled parameter of the editor's OnSpellingCheck event to perform a live spelling check.
All spelling check interface components implement both live spelling check (spelling check in a background thread) and a traditional spelling check using dialogs
Component  |
Requires  |
Thesaurus  |
Auto-correction  |
Dialog Localization  |
Dialog Type  |
Win32/Win64  |
Parser is implemented by  |
Yes  |
Yes  |
Classic/Word  |
Win32+Win64  |
TRichView  |
Yes  |
Yes  |
Yes1  |
Classic/Word  |
Win32+Win64  |
Spell checker  |
Yes  |
Classic/Word  |
Win32  |
TRichView  |
Yes  |
Yes2  |
Classic/Word  |
Win32+Win64  |
TRichView  |
Yes  |
Classic/Word  |
Win32+Win64  |
TRichView  |
Yes  |
Yes3  |
Classic  |
Win32  |
TRichView  |
Localization:
1: a spelling form is localized by the spelling checker, RichViewActions select the most appropriate language for TRVAControlPanel.Language automatically.
2: a spelling form is localized by the spelling checker.
3: a spelling form can be localized by the spelling checker, however, ready-to-use localized text is not supplied.
See also
