       << Click to display table of contents >> TRVAControlPanel.SpellInterface |
Allows using a third-party components to correct spelling errors and to find synonyms.
property SpellInterface: TRVACustomSpellInterface;
You can assign one of the following components to this property:
•TRVAAddictSpellInterface (to use Addict)
•TRVAASpellInterface (to use ASpell)
•TRVADXSpellInterface (to use ExpressSpellChecker)
•TRVAHunSpellInterface (to use HunSpell)
•TRVAPolarSpellInterface (to use Polar SpellChecker)
