       << Click to display table of contents >> Interfaces for Third-Party Components |
RichViewActions interface components is a group of components allowing RichViewActions to use third-party components.
A third-party component is assigned to a property of an interface component, and this interface component is assigned to a property of TRVAControlPanel.
This indirect linking allows using RichViewActions and third-party components together, without losing a possibility using them separately, because:
•RichViewActions units do not refer to units of third-party components
•units of third-party components do not refer to RichViewActions units
•only units of interface components refer to the both of them.
RichViewActions support the following types of interface components:
