TSRVTabSet.TabHeight
Defines the height of tabs.
property TabHeight: TRVPixel96Length;
For horizontal tab set controls, this property defines the height of tabs.
For vertical tab set controls, this property defines the widths of tabs.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
See also:
Margins
Indent
TextAlignV
