TSRVTabSet.Indent
TSRVTabSet.Indent
Adds spacing before text in each tab.
property Indent: TRVPixel96Length;
If the tab has an icon, this is a distance between the icon and the text.
If the tab does not have an icon, this is a distance from the tab's Margin to text.
This value is measured in pixels at 96 pixels per inch; the actual size scaled according to the current screen pixel density.
Default value:
5
