TrvActionCustomIO.FileName
Specifies the default file name.
property FileName: TRVALocString;
This property is assigned to FileName property of the file open/save dialog before showing it.
This property is used and public in the following actions:
TrvActionExport
TrvActionInsertFile
TrvActionInsertPicture
Default value:
'' (empty string)
See also properties:
InitialDir
AutoUpdateFileName
