TrvActionCustomIO.InitialDir
Specifies the initial directory for the file dialog.
property InitialDir: TRVALocString;
This property is used only if FileName is empty.
It is assigned to InitialDir property of the file open/save dialog before showing it.
Default value:
'' (empty string)
