TrvActionCustomIO.AutoUpdateFileName
Specifies whether FileName is automatically updated by the action.
property AutoUpdateFileName: Boolean;
If this property is True, FileName property is updated when the action is successfully executed (the user chose a new file from dialog).
This property is used and published in the following actions:
TrvActionExport
TrvActionInsertFile
Default value:
True
