       << Click to display table of contents >> TSRVTabItem.SkinFontIndex |
Specifies which font is used for this tab in the skin mode.
property SkinFontIndex: Integer;
In a no-skin mode, a tab's font is defined in the Font property of the tab set control.
In a skin mode, a tab's fonts are defined in TabSet.SkinManager.CurrentSkin.Fonts[FontIndex],
where FontIndex is a value of FntTab property of SkinManager.CurrentSkin.HorizontalTabSetSchemes/VerticalTabSetSchemes[SkinSchemeIndex],
where SkinSchemeIndex is SkinSchemeIndex property of the tab (if not negative) or TabSet.SkinSchemeIndex.
Default value:
-1
