       << Click to display table of contents >> TSRichViewEdit.OnMarginsChanged |
Occurs before margins are changed.
type
TSRVMarginsChangedEvent = procedure(Sender: TSRichViewEdit;
var NewLeft, NewTop, NewRight, NewBottom : Integer;
OldLeft, OldTop, OldRight, OldBottom : Integer) of object;
property OnMarginsChanged : TSRVMarginsChanged;
NewLeft, NewTop, NewRight, NewBottom – new margins, pixels.
OldLeft, OldTop, OldRight, OldBottom – old margins, pixels.
Unlike values of LeftMarginPix, TopMarginPix, RightMarginPix, BottomMarginPix properties, these parameters contain unscaled values (as if ViewProperty.ZoomPercent=100).
If one of Old*** parameters is equal to -1, this margin was not changed; the corresponding New*** parameter must be ignored.
If you assign -1 to one of New*** parameters, this margin will not be changed.
This event occurs:
•when assigning new values to LeftMargin, RightMargin, TopMargin, BottomMargin properties of PageProperty, or
•when calling SetMargin, SetMarginMM or SetMarginUnit methods.
Example:
// SRVPrint: TSRVPrint is placed on the form
procedure TForm1.SRichViewEdit1MarginsChanged(
Sender: TSRichViewEdit; var NewLeft, NewTop, NewRight,
NewBottom: Integer; OldLeft, OldTop, OldRight, OldBottom: Integer);
ValueLeft, ValueRight, ValueTop, ValueBottom : Integer;
if SRVPrint1.CheckMargin(ValueLeft, ValueTop, ValueRight, ValueBottom,
NewLeft, NewTop, NewRight, NewBottom) then begin
NewLeft := ValueLeft;
NewTop := ValueTop;
NewRight := ValueRight;
NewBottom := ValueBottom;
