TRVCrossTabLevel.SortType
Specifies how columns are ordered at this level of a cross-tab report.
type
  TRVReportSortType = (rvrstNoSort, rvrstAscending, rvrstDescending,
    rvrstCaptionsAscending, rvrstCaptionsDescending);
property SortType: TRVReportSortType;
This property is used if TRVReportTableItemInfo.CrossTabulation.ColumnGenerationType is one of:
•rvcgtDataQuerySeparate
•rvcgtDataQueryCascade.
In these column generation modes, values (and, optionally, captions) are taken from the results of TRVReportTableItemInfo.RowGenerationRules[0].DataQuery.
Values are in FieldName field, captions are in CaptionFieldName field.
Value
Meaning
rvrstNoSort
No sorting, values are sorted in the order of their appearance in the results of a date query
rvrstAscending
Values are ordered from low to high
rvrstDescending
Values are ordered from high to low
Values are sorted so that captions are ordered low to high; if captions are not defined, this mode works like rvrstAscending
Values are sorted so that captions are ordered high to low; if captions are not defined, this mode works like rvrstDescending
Text values and captions are compared using CaseSensitive property.
Default value:
rvrstAscending
See also
•Definitions of Report Workshop terms
