TRVCrossTabLevel.CaptionFieldName
A name of data field that can be used to show captions of cross-tab columns.
property CaptionFieldName: TRVUnicodeString;
If this property is not empty, it defines an alternative caption for columns of this level of the cross-tab table. This caption can be displayed (see cross-tab heading field syntax).
This property is used if TRVReportTableItemInfo.CrossTabulation.ColumnGenerationType is one of:
•rvcgtDataQuerySeparate
•rvcgtDataQueryCascade.
•rvcgtAutoSeparate
•rvcgtAutoGroup
This property is useful if FieldName field contains some identifier, while a text description is stored in another field.
If SortType = rvrstCaptionsAscending or rvrstCaptionsDescending, and TRVReportTableItemInfo.CrossTabulation.ColumnGenerationType = rvcgtAutoSeparate or rvcgtAutoGroup, captions are used when sorting columns at this level of cross-tab (see also CaseSensitive property).
Example
A data table for a cross-tab report is named "OrdersTable", it has fields: OrderId, ItemId, Quantity.
There is another table "ItemsTable", it has fields: ItemId, ItemName.
We want to build a cross-tab report that uses ItemId for cross-tab columns, but we want to display ItemName in the table header.
The simplest example of a template table for this report is below:
Order
{#ItemName}
N {OrderID}
{Quantity}
Table.CrossTabulation.ColumnGenerationType :=
  rvcgtDataQuerySeparate;
Table.CrossTabulation.Column := 1;
Table.CrossTabulation.FirstRow := 0;
with Table.CrossTabulation.Levels.Add do
  DataQuery :=
    'SELECT ItemId, ItemName FROM ItemsTable ORDER BY ItemName';
  FieldName := 'ItemId';
  CaptionFieldName := 'ItemName';
with Table.RowGenerationRules.Add do
  FirstRow := 1;
  RowCount := 1;
  DataQuery := 'SELECT * FROM OrdersTable';
  KeyFieldNames := 'OrderId';
The resulting report table looks like:
Order
Item A
Item B
Item C
N 10001
1
2
3
N 10002
3
3
3
N 10003
4
1
1
N 10004
2
3
3
Default value:
'' (empty string)
See also
•Definitions of Report Workshop terms
