TRVMediaServer.OnPacketProcessing, OnConnectionCountChanged
The events allowing to display information about the server status.
type
  TRVMSCountEvent = procedure(Sender: TRVMediaServer;
    const Count : Integer) of object;
property OnPacketProcessing: TRVMSCountEvent;
property OnConnectionCountChanged: TRVMSCountEvent;
OnPacketProcessing occurs when a new packet is received or processed. Count is the number of accumulated packets.
OnConnectionCountChanged occurs when a count of connections is changed. Count is the number of connections (a connection is a channel to TRVCamReceiver)
These events can be useful to show information about the server status; you can show how much the server is busy.
See also:
•OnUserConnect, OnUserDisconnect
