       << Click to display table of contents >> TRVCamView.WaitAnimationDelay |
Specifies the delay (in ms) before displaying an animation that shows that the component waits for a next video frame.
property WaitAnimationDelay: Integer;
This animation is displayed only if VideoSource is TRVCamera. A countdown to the animation starts when video starts playing (when TRVCamera.OnStartVideoStream or OnStartVideoFile is called) and resets when a next video frame is drawn.
Note 1: Video must be started after linking this viewer to the camera (i.e. OnStartVideoStream or OnStartVideoFile must happen when the components are linked), otherwise an animation will not be displayed.
Note 2: The following events stops a countdown and an animation: VideoSource is changed; video is stopped (when TRVCamera.OnEndVideoStream or OnEndVideoFile is called).
Assign a zero value to this property to disable this feature.
Default value
3000 (3 seconds)
See also
•TRVCamMultiView.WaitAnimationDelay
