       << Click to display table of contents >> TRVCamView.ShowCameraSearch |
Indicates whether the control displays a special panel while searching for the camera.
property ShowCameraSearch: Boolean;
The panel contains some text, animation and “Abort” button.
The “Abort” button uses Font property for text, its colors are not customizable.
The animation is defined in IconStyle property.
A color of the panel itself is chosen automatically depending on IconStyle property, or can be specified explicitly in SearchPanelColor property.
A text uses Font property, its color is chosen automatically depending on IconStyle property, or can be specified explicitly in SearchPanelTextColor.
Default value
True
