       << Click to display table of contents >> TRVCamView.SearchPanelColor, SearchPanelTextColor |
These properties specify colors of a camera search panel.
property SearchPanelColor: TRVMColor;
property SearchPanelTextColor: TRVMColor;
This panel is shown when TRVCamera.SearchCamera is called, if ShowCameraSearch = True.
By default (value of this property is clNone/Null), the viewer uses default colors that depend on IconStyle property.
SearchPanelColor overrides a background color of a search panel.
SearchPanelTextColor overrides a text color of a search panel.
[FMX note]: these colors can be semitransparent (opacity is defined in the color's alpha channel)
Default value [VCL and LCL]
clNone
Default value [FMX]
TAlphaColorRec.Null
