       << Click to display table of contents >> TRVCamView.FrameScaleQuality [VCL and LCL] |
Specifies the image scaling algorithm.
type // defined in MRVType unit
  TRVMFrameScaleQuality = (rvmfscLow, rvmfscNormal);
property FrameScaleQuality: TRVMFrameScaleQuality
This property is used only in VCL and LCL for Windows, for all values of RenderMode.
Value  |
Animation  |
rvmfscLow  |
Low quality, quick, low CPU (or GPU) usage  |
rvmfscNormal  |
Normal quality  |
Frames are scaled according to ViewMode.
Initial value
rvmfscNormal
