       << Click to display table of contents >> TCustomRVMicrophone.NoiseReduction, NoiseReductionLevel, UseRNNoise |
Noise reduction.
property NoiseReduction: Boolean;
property NoiseReductionLevel: Integer;
property UseRNNoise: Boolean;
NoiseReduction turns noise reduction on/off.
This property is applied to sound read from a microphone. If WAVUseOptions=True, it is applied to sound from WAV-files as well.
The component supports two ways of noise reduction.
RVMediia implements a noise reduction algorithm that performs a fast Fourier transform and filtering results.
NoiseReductionLevel is used if NoiseReduction = True. It defined the level of noise reduction. The recommended range of values is 0..100. 0 means no reduction, higher values apply higher noise reduction (but may lead to higher sound distortion).
If RNNoise library is available, and UseRNNoise = True, the component can use RNNoise, a library that implements a noise reduction based on a recurrent neural network. Usually, RNNoise's results are better than RVMedia's own results.
NoiseReductionLevel is not used in this mode.
Note: this mode works much better for 16-bit samples than for 8-bit samples (see BiitsPerSample).
Default value:
•NoiseReduction: True
•NoiseReductionLevel: 20
•UseRNNoise: True
See also
