       << Click to display table of contents >> TCustomRVMicrophone.BitsPerSample, SamplesPerSec |
The properties define quality of sound read from a microphone.
property SamplesPerSec: TRVSamplesPerSec;
property BitsPerSample: TRVBitsPerSample;
Higher values may increase sound quality, but they increase traffic and lag as well.
"Samples per second" is often called "sample rate", "bits per sample" is often called "sample size".
Default values
•SamplesPerSec: rvsps8000
•BitsPerSample: rvbps8
See also
