TCustomRVMicrophone.WAVFileName
Specifies the name of a WAV-file.
property WAVFileName: String;
The component reads sound from this file if SourceType=rvsstWAV
Assigning a value to this property does not start processing a file. After assigning this property, assign Active=True (even if it is already True).
The component supports only uncompressed WAV files.
See also
•WAVUseOptions
