       << Click to display table of contents >> TrvCustomAction.Hint (with TNT Controls) |
Indicates the Help hint for client controls and menu items.
If TNT Controls are used, this property overrides the standard action's Hint property.
property Hint: WideString;
Hint holds the string that is the hint for that action when it is set. This value is propagated to client controls and menu items.
See also properties:
