       << Click to display table of contents >> TrvCustomAction.Disabled |
Allows to disable the action.
property Disabled: Boolean;
If False, the action is disabled and enabled automatically.
If True, the action is disabled.
Default value:
False
See also properties:
•Enabled
See also:
