       << Click to display table of contents >> TRVAPopupMenu.OnLiveSpellGetSuggestions |
Occurs when the menu needs to add items containing suggestions for the current misspelled word.
type
TRVALiveSpellGetSuggestionsEvent = procedure (Sender: TRVAPopupMenu;
Edit: TCustomRichViewEdit; const Word: TRVUnicodeString;
StyleNo: Integer; Suggestions: TRVASpellStrings) of object;
TRVA2LiveSpellGetSuggestionsEvent = procedure (Sender: TObject;
For TRVAPopupMenu:
property OnLiveSpellGetSuggestions: TRVALiveSpellGetSuggestionsEvent
For TRVATBPopupMenu, TRVATBXPopupMenu, TRVASPTBXPopupMenu:
property OnLiveSpellGetSuggestions: TRVA2LiveSpellGetSuggestionsEvent
This event is used for live spelling check.
Word is a misspelled word.
StyleNo is an index of text style for this word in Edit.Style.TextStyles.
Add suggestions to Suggestions.
If SpellInterface is used, this command is processed automatically.
Otherwise, use this event for generating suggestions.
See also:
