       << Click to display table of contents >> TrvActionParagraph.LastLineAlignment |
Specifies the alignment for applying to the last line of selected justified and distributed paragraphs.
property LastLineAlignment: TRVLastLineAlignment;
If UserInterface=False and rvpimLastLineAlignment in ValidProperties, the action applies this property to the selected paragraphs.
If UserInterface=True, the action displays a paragraph dialog (initialized with properties of the selected paragraphs); if the user changed value of this property in the dialog, rvpimLastLineAlignment is included in ValidProperties, and the action applies this property to the selected paragraphs.
This property is applied to the paragraph style's (RVStyle.ParaStyles[]) property of the same name.
