       << Click to display table of contents >> TrvActionParagraph.KeepWithNext |
Specifies the keep-with-next option for applying to the selected paragraphs.
property KeepWithNext: Boolean;
If UserInterface=False and rvpimKeepWithNext in ValidProperties, the action applies this property to the selected paragraphs.
If UserInterface=True, the action displays a paragraph dialog (initialized with properties of the selected paragraphs); if the user changed value of this property in the dialog, rvpimKeepWithNext is included in ValidProperties, and the action applies this property to the selected paragraphs.
This option adds/removes rvpaoKeepWithNext in the Options property of styles of the selected paragraphs (RVStyle.ParaStyles[].Options).
