       << Click to display table of contents >> TrvActionItemProperties.ActionInsertTable, UpdateAllInsertTableActions |
ActionInsertTable specifies the "insert table" action for applying default properties to.
UpdateAllInsertTableActions allows applying to all actions "insert table" actions on the same form/datamodule.
property ActionInsertTable: TrvActionInsertTable;
property UpdateAllInsertTableActions: Boolean;
If "Default" checkbox is checked, when properties are applied, they are assigned to "insert table" and "insert horizontal line" action as well, so they become default properties for new tables / lines.
If ActionInsertTable is defined, properties are applied only to this action. If this link is not defined, they are applied to the first found TrvActionInsertTable action on the same form/datamodule (if UpdateAllInsertTableActions=False), or to all TrvActionInsertTable actions on the same form/datamodule (if UpdateAllInsertTableActions=True).
Note: Report Workshop includes an additional action for inserting a report table: TrvrActionInsertTable, inherited from TrvActionInsertTable. If you want to apply changes both to instances of TrvrActionInsertTable and TrvActionInsertTable, UpdateAllInsertTableActions must be True.
Default value
UpdateAllInsertTableActions = True
See also:
•DefaultChecked, DefaultPersistent
•TrvActionTableProperties.ActionInsertTable, UpdateAllInsertTableActions
