       << Click to display table of contents >> TrvActionItemProperties.ActionInsertHLine |
Specifies the "insert horizontal line" action for applying default properties to.
property ActionInsertHLine: TrvActionInsertHLine;
If this link is not defined, the first found TrvActionInsertHLine action on the same form/datamodule is used.
If "Default" checkbox is checked, when properties are applied, they are assigned to "insert table" and "insert horizontal line" action as well, so they become default properties for new tables / lines.
See also:
