       << Click to display table of contents >> TrvActionExport.ExportToFile |
Saves Edit in the specified file in the specified format.
function ExportToFile(Edit: TCustomRichViewEdit;
const FileName: TRVUnicodeString;
ExportFormat: TrvFileExportFilter;
ConverterOrCustomIndex: Integer;
rvc: TRVOfficeConverter): Boolean;
Parameters:
Edit – editor for saving.
FileName – file name for saving.
FileFormat – file format for saving.
CustomFilterIndex used only if FileFormat is ffeCustom or ffeOfficeConverters.
If FileFormat = ffeCustom, CustomFilterIndex identifies a custom file format. Custom formats are numbered from 1 in the order they are listed in the CustomFilter property.
If FileFormat = ffeOfficeConverters, CustomFilterIndex identifies a format supported by Microsoft Office file export converters. Formats are numbered from 0. A list of these formats and their order are different on different computers. This is the index in rvc.ExportConverters collection.
If saving is unsuccessful, an error message is displayed.
Return value:
True if the saving was successful.
